Built for Van
See What's Behind Your Cargo Van.
No rear window. A wall of cargo. Mirrors that show you nothing but plywood. The G900Pro puts a live 2.5K feed from your rear bumper straight onto your mirror — so you can finally see the road behind you.
Blocked Rear View
Cargo Blocking Your Rear View?
See clearly behind your van, even when it’s fully loaded.
BUILT FOR VANS
Pick Your Kit
G900Pro
WOLFBOX G900Pro Smart Rear View Mirror Dash Cam & Backup Camera
G900Pro Mirror Dash Cam
4.7 · 2,418 reviews
£226.80 £324.00 SAVE 30%
Free UK shipping · 30-day returns · 2-year warranty
Choose your kit
Quantity
1
In stock — ships within 48 hours
Specifications
Built to Record, Not Just to Watch.
Clear Day or Night.
From bright daylight to low-light roads, high-resolution cameras keep your view clear and detailed when you need it most.
4K (F) +2.5K (R)Sony STARVIS 2
RHD DesignUK Exclusive
More Features. More Control.
Customize your view and driving experience with a range of smart features designed to fit the way you drive.
See Beyond Your Cargo.
The rear camera gives you a clear view of the road behind—even when your cargo blocks the rear window.
Clean, OEM-Style Installation.
Use an OEM bracket for a secure, seamless fit that looks like it belongs in your van from the start.
Specification
The Factory Mirror Costs More and Records Nothing.
Factory digital mirror G900ProRecommend
Price Most £1,000+ £226.8
Live rear view Yes Yes
Records what it sees — 4K front + 1080p rear
Parking mode — 24 h motion + impact
Incident footage for claims — G-sensor locked clips
Can be added to a van you already own — Yes
Install Factory build only 45–60 min, DIY, reversible
Moves to your next van — Yes — unclips
Same live rear view. Plus the footage — for a fraction of the option price.
See the kits
Bracket On. Camera Back. Done in an Hour.
The bracket locates on the factory Van mirror stem — no drilling, no adhesive on the glass, and it comes off without a trace.
Above the rear doors on the roof lip — clear of the cargo line and the door swing. Screw mount or 3M VHB pad, both in the box.
The 26 ft shielded cable tucks into the headliner trim and down the A-pillar. Power from the 12 V socket, or hardwire the fuse box for parking mode.
  • 45–60 minDIY install
  • No drillingFully reversible
  • OEM bracketNo vehicle-specific parts
Owner Footage
Shot From the Driver's Seat.
Clips owners sent us — loaded vans, night merges, tight yards. Tap any one to watch it full-size.
Reviews
From Drivers Who Live in Their Van.
4.7/ 5
2,418 verified reviews from van owners
Ten years of backing a Transit blind. First week with this and I stopped getting out to check.
Marcus R.· Transit 250· Verified
Night view is the part that sold my crew. You can actually see the car behind you, not just its headlights.
Dana T.· Transit 350 HR· Verified
Cable route took me longer than 45 minutes, but the bracket clipped straight on and it looks factory.
Jorge L.· Transit 150· Verified
Fitted all six vans in our fleet. Two backing claims last year, none since.
Sam K.· Fleet manager· Verified
Got rear-ended on a delivery route. The 4K clip settled the claim in a day.
Priya A.· Transit Crew· Verified
Loaded floor to roof every morning. The mirror is the only reason I can merge on the interstate.
Terrence B.· Transit 250 MR· Verified
Get Started
Take Back Your Rear View.
Fits Ford Transit 150, 250 and 350 — cargo, crew and high-roof — model years 2015 to 2026. Everything you need is in the box.
  • 30-day returns
  • 2-year warranty
  • Free US shipping
  • Fleet pricing at 5+ units
Questions Van Owners Ask.
No — that's the whole point. The camera mounts on the outside of the rear doors, so it works identically on a fully panelled cargo van, a bulkheaded crew van, or a van loaded floor-to-roof. Glass changes nothing.
The G900 Pro can be installed in multiple ways to fit your vehicle. Choose from an OEM bracket, strap mount, or dashboard mount for a secure and flexible installation.
45 to 60 minutes for a first-time DIY install. Most of that is tucking the rear-camera cable into the headliner. Hardwiring the fuse box for parking mode adds about 20 minutes. There is a full video walkthrough above.
Always on, from key-on — which is what makes it useful for lane changes rather than just parking. Shifting into reverse switches to a wider low-angle view with guide lines, then returns automatically.
Yes — both channels write in parallel to one card, not alternately. Front records at 4K, rear at 2.5K, and a G-sensor event write-protects the clips on both channels so the loop cannot overwrite them.
No. The included hardwire kit has a low-voltage cutoff that shuts the unit down before your starter battery is compromised.
The rear camera is IP67 rated with a hydrophobic lens coating. Keep a pressure-washer lance at least 12 inches from the housing and don't aim it at the cable gland.
It mounts within the factory mirror's footprint — no additional windscreen obstruction. Rules vary by state and country, so check your local regulations. Commercial fleets should confirm with their DOT or insurer.
No More Blocked View
Your cargo isn't going to move out of the way. Put a 2.5K camera behind it and drive your Van like it has a rear window.
30 Months Warranty —— Built for Vans
