4 Ways to Improve Dash Cam Video Quality
Sometimes, confusing tech specifications of a dash cam can create serious problems for you. Since even if you have the most expensive model, it doesn’t guarantee it will be able to produce the best video quality, especially if you don’t understand its highs and lows.
Therefore, if you want to get the most out of your dash cam and record the best quality footage, it is imperative to perceive a few important factors that can significantly improve the dash cam video quality.
The Resolution – Everyone Can Change the Resolution of Your Dash Cam Easily
We know this is probably the first thing everyone considers before purchasing a dash cam. Surprisingly, many people think the resolution they have is a built-in setting and it can’t be changed. The reality is most models do have different resolution settings. And you can change them easily. With WOLFBOX’s dash cam, you can get a a clearer view of resolution.
Occasionally, while installing the dash cam and playing with its settings, some people mistakenly change the settings and then don’t perceive what is causing the low video quality. For that reason, the first thing you need to do is to make sure the right resolution settings are selected. You can check that by going to your cam settings.
In case you are thinking why dash cam models still come in low resolution if they are good for nothing, well, lower settings are helpful when you are planning to capture details while in motion.
Especially, when you have both 2K and 4K settings, 2K settings are lower but they are able to produce a smoother video than 4K in an utter, quick motion.
To tell you the truth, these days the minor changes to these settings don’t matter much. Even the highest-resolution model works pretty well when your car is in motion. They capture smooth video and they don’t miss any details either.
If you want to know more about the different resolutions of a dash cam, read this post.
The Field of View Also Affects The Video Quality
We all love to have a larger field of view. It feels like a luxury and gives us more perception on the road. The common field of view settings are between 130 degrees and 160 degrees. If your settings are focused on the max field of view, this means your camera has a wider angular field of view. This looks good definitely but at the cost of distortion. WOLFBOX G880 dash cam has 3 channel mirror dash cam with 170° front camera, 140° inside camera, & 150° rear camera.
In addition, a wider angular field of view also decreases the resolution. It isn’t so noticeable, but the difference is there.
If you and your friend both have a 4K dash cam, and you have a wider angular field of view than your friend, the dash cam video quality of your friend will be better. To match the fine quality of your friend’s dash cam, you will have to lower the field of view settings of your cam too.
There is one more factor that is directly connected with the Field of View.
Glare & Reflection!
It lowers the video quality, and in fact, it sometimes makes you feel like you are watching a standard 360 footage (starting line resolution), not the 4K one.
To control the glare and reflection, you can use Circular Polarizing Lens (CPL). It is extremely effective in preventing glare and reflection. You just need to put and adjust it over your existing dash cam lens.
Use Your Dash Cam to Capture The Road, Not Sky
When it comes to dash cams, the number one problem we notice in most cars is the “Position”. People position their cameras in an incorrect manner. Instead of capturing the road and their route ahead, they capture the sky. WOLFBOX T10 Plus has full 2.5K HD resolution front and 1080p rear camera with 170° front, and 140° rear lens.It is an excellent choice for traveling, and the best value for money!
When your camera takes the amount of sky more than the road, it distorts the video quality automatically. No manual settings can improve and give you the best possible results. Since the sky is packed with sunlight which darkens the video. The lens attempts to compensate for the brightness by reducing the quality too so that it can produce better footage.
Likewise, if your dash camera captures the sky more than the road, the nighttime video quality won’t be great either. The street/building lights can make it harder for the lens to capture the details of other vehicles. Wolfbox G900 dash cam.
We are not saying it’s wrong to capture the sky, particularly if you love capturing the meteorite landing or outdoor environment. We are just trying to explain that this can be one of the factors that you aren’t fully enjoying the top video quality of your dash cam.
Other than that, ensure that you are capturing the video right from the center of your windscreen because if the camera isn’t positioned at the center, it covers fewer angles and misses the details of the other side of the road.
Keep Your Windscreen Super Clean
This is the last and simplest thing you can do if nothing is working in your favor.
It’s probably your windscreen that is causing lower video quality.
The dirty windscreen doesn’t cause the problem in just one way. It actually causes problems in many ways. For example, even if it has a small amount of dust on it or some scratch, it can catch the incoming light from the road and make it intense and brighter. This showers the camera lens with glare and ruins its entire effectiveness.
When you have dust on the windscreen, the windscreen is also more likely to fog-up too. You perhaps won’t notice that in the beginning, but your dash cam will be affected by it.
The light fog factor will reduce its overall visibility and make you believe that something is not correct with your camera settings.
In some cases, the dirt and the fog effects are stubborn.
They can’t be wiped by the wipers. You have to deep clean them or contact a professional who can polish the entire windshield in a correct, firm motion.
All in all, if you aren’t satisfied with the video quality of your dash camera, focus on these four factors. They are directly associated with the video quality, and they determine the overall clarity of the footage. Besides, if you deal with adverse situations, such as extreme weather and poor lighting, correcting the above factors can prevent their effects and ensure that you are getting the most from your camera.
Why Every Uber Driver Needs a Dashcam?
